23.02.19 , 17:02
Pages: 1 ... 73 74 75 76 77 78 79 80 81 82 83 84 [85] 86 87 88 89 90 91 92 93 94 95 96 97 ... 110
Author Topic: Обговорення Інтерсіті+ Київ-Перемишль  (Read 115307 times)
Undertaker
« Reply #840 on: 12.07.18 , 15:07 »
Тут скорее политика УЗ интересно, не ПКП. Как я написал, не давно вроде IC+ не ожидал даже 30 минут.
Да, штраф в 250 шв.фр. за каждые полчаса опоздания на границе по вине ПКП быстро им мозги вправит. Однако, эта проблема с пересадкой не новая, а тянется почти с самого начала существования ИС+ в Пшемысль, тем не менее в отсутствии компетентных людей в ЦЛе, из-за их бездействия до сих пор вопрос не решен.
« Reply #841 on: 12.07.18 , 16:07 »
Johannes, you've quoted post of person without specifying which exactly of IC+ he've used.
And I suggest primarily suggested connection was not to 705, but to 715.
AFAIK the choice between "wait" vs "depart on time and break the connection" is made in different way in case of 705 and 715.
705 is "very loyal", this train waits even in case of very serious late of PKP train, while 715 oppositely is "less-loyal", waits only in case of insignificant late of previous train.
It's quite obvious why - non-waiting in case of change of 715 means trapping to Lviv only 2,5 hours later, while in case of 705 - all is much worse, arrival to Lviv 3,5 hours later and more problematic in other aspects.
« Last Edit: 12.07.18 , 17:07 by Maxy » Logged
« Reply #842 on: 12.07.18 , 17:07 »
That might very well be the case, yes. That would certainly explain the apparent paradox. He did write something about getting the next train instead and having to buy a new ticket for it (yet another indicator that he missed 715 and had to go by 705). Thanks. But this is the policy of UZ, not of PKP, right?
« Reply #843 on: 12.07.18 , 18:07 »
AFAIK UZ don't have policies regulating things like this.
Not sure if PKP policies are applicable here.
AFAIK all this practice is beyond the regulated area, just arbitrariness according somebody's imagination about Pareto-optimum.
« Last Edit: 12.07.18 , 19:07 by Maxy » Logged
« Reply #844 on: 12.07.18 , 20:07 »
И вправление будет примерно следующим: поляки скажут "ну его нахрен" и принципиально сделают график таким, что прибытие поездов с запада в Перемышль будет выглядеть так: 1) за два часа до отправления поезда на Киев и 2) через 5 минут после отправления поезда на Киев. Кошка бросила котят, пусть гуляют как хотят.
зато львовский пассажир до Киева страдает систематически.
А это уже проблема УЗ. Захотела скрестить ежа с ужом (популистский поезд в Польшу + скоростной Львов-Киев) - пусть теперь сама крутится.
romko
« Reply #845 on: 12.07.18 , 23:07 »
Добрий вечір!
Для того, щоб встигнути на ІС Перемишль-Київ (ч/з Хмельницький), яким потягом краще їхати з Кракова - TLK 83170 Ustronie чи IC 6300? У якого з них більша імовірність запізнення?
І що там зі станцією Kraków Główny зараз відбувається? Чому рекомендують сідати до потягів ІС на станції Kraków Płaszów?
« Reply #846 on: 13.07.18 , 01:07 »
Если один из них опаздывает, то другой тоже может. Рельсы одные 😀
Кажется что 6300 меньше опаздывает, но если хотите со запасом, то едете двумя электричками в 7:40 из Кракова.
Будет время на прогулку по Пшемысля, красивый украинский город.
Весной был ремонт между GŁÓWNY и PŁASZÓW и часть поездов не следовали из главного из-за окон. Сейчас это уже не актуально, все поезда снова следуют из главного.
« Last Edit: 13.07.18 , 01:07 by Andersen » Logged
« Reply #847 on: 13.07.18 , 01:07 »
TLK 83170 Ustronie все ж раніше прибуває (12.31), ніж ІС6300 (12.53).  Я б обрав перший з них.
Щодо поради сідати на Кракові Плашові чи на Кракові Головному,  то за стандартний розкладом обидва ці потяги мають зупинку і там,  і там.  Тому обирайте самі звідки Вам зручніше їхати.
Хоча Ви ж не вказали точну дату поїздки,  може там ремонти якісь будуть.
« Reply #848 on: 13.07.18 , 08:07 »
не совсем так.
такая логика имела-бы смысл если-бы опоздание набиралось-бы между Краковом и Пшемыслем. Или если бы вероятная задержка первого была бы не больше интервала между первым и вторым.
А вот если опоздание генерируется ПЕРЕД Краковом и его величина больше, чем интервал между поездами - то второй может уйти по графику, а опаздывающий первый окажется позади.
А в этом сезоне главный генератор опозданий наблюдаемых межлу Краковом и Перемышлем - как раз в основном перед Краковом
« Reply #849 on: 13.07.18 , 11:07 »
Хорошо, известно ли из-за чего те опаздание?
